Power Automate - Add tabs for a recipient on an envelope
Hi All,
In my document i have an anchor string “I:” in multiple places and the connector is adding at all places where it finds “I:”, but when I try to enter some values in those text boxes, same value is being taken automatically in every text boxes in the document.
Sample Image
I entered - Test2 in the first text box and same value is being auto populated in other two text boxes as well.
Can anyone help me on the same?
Regards
Sasikanth
@Sasi007
The overriding of fields will occur if the fields have the same data label.
Could you try adding a unique tab label for each field?
You can read more about data labels here: https://support.docusign.com/s/document-item?language=en_US&bundleId=gbo1643332197980&topicId=nas1578456281970.html&_LANG=enus
This is a post with the same question and shows an example of a fix using C#.
https://community.docusign.com/esignature-api-63/is-there-a-way-to-place-two-date-tabs-19791
@Sasi007
