System Validation Certification for DocuSign
Greetings.
I was asked if there’s a System Validation Certification for DocuSign?  Our Research Administration Office (RAO) is requesting for that certification per a study sponsor's request since RAO uses DocuSign to capture study patient consenting workflow.  Please advise if it’s stored somewhere in our domain, or I have to request Support for that.
Thank you.
Jess Allas
June 7, 2024
@Jess Allas
You can visit the DocuSign Trust Center where you can find a variety of compliance certifications, reports, and security details.  Look for relevant documentation under the "Certifications & Reports" section.
If you cannot find the specific validation certification required by your Research Administration Office (RAO), you may need to request it directly from DocuSign Support.
June 7, 2024
@Jess Allas
Thank you, John.  Will check the DocuSign Trust Center and see what’s under Certifications & Reports.
Thanks again.
Jess Allas
Hi @Jess Allas,
