Signer doesn't recieve envelope when more than one signer is assigned (with a set order)
  • July 16, 2024
  • 2 replies
  • 94 views
Whenever I set a document to have two signers, the firs one (in our organization) never gets the envelope to add the first signature. I am forced to send the envelope multiple times. What am I doing wrong? This happens regardless of whether I check the “Set signing order” or not.
Any guidance is appreciated.
Dan
Best answer by JohnSantos
@Dan_Ornelas
Verify that email notifications are not being blocked or filtered into spam/junk folders. Sometimes organizational email filters can block these notifications or the user might have disabled them.
If they have a DocuSign account, is the envelope going to their Inbox in DocuSign?
July 16, 2024
@Dan_Ornelas
Hi @Dan_Ornelas,
