You will need to give admin permission within the account to another user in order to delegate.
Could you clarify what you meant by Auto escalation?
Please let us know if you need further assistance with anything else and click "Select as Best" below if you find the answer a valid solution to your issue!
You can create a case at https://support.docusign.com/en/contactSupport and a Support agent will contact you, If you are not able to open the case on the same page, you should scroll down to More Support Options and select "I can't reset my password or don't have an account." you will have the option of filling out the form or calling Support.
Christopher | DocuSign Community Moderator
Back to Docusign.com
