Inquiry About Remaining Signature Counts for Standard Pro Plan
  • January 23, 2025
  • 3 replies
  • 105 views
I am reaching out regarding my subscription to the Standard Pro Plan, which I recently switched to after using a Business Pro trial. I understand that the Standard Pro Plan allows for up to 100 signatures annually.
However, since the report combines the usage from the trial period with my current subscription, it is difficult to determine how many signature slots remain for my Standard Pro Plan specifically. Could you kindly clarify where I can find the remaining signature count exclusive to the Standard Pro Plan?
Best answer by Christopher.Alpizar
Hello ​@KCRN Research Korea,
Per the community guidelines (https://community.docusign.com/site/terms) we can only provide you with general information, the Account Admin will need to contact Support directly for Billing Inquiries, Account Change Requests, or Feature enablement. To open a support case in the Docusign Support Center, go to the "Get Support" section and select "Open a Support Case". Log in using your Docusign credentials and select a case subject. If you have multiple Docusign accounts, choose the appropriate account to continue. Open a case in the Docusign Support Center.
You could create a custom report starting the day you acquire the Standard plan and then subtract the amount from the envelope allowance. Create a Custom Report
Could you please confirm that the remaining usage is as detailed below?
-Usage Envelopes : 1
-Remaining Envelopes : 99 (After compelted siging 3 envelopes, the usage is 4 and the remaining is 96.)
Thank you for your assistance. Please let me know if there are any discrepancies or if further information is required.
Can you DM your account number and email to confirm at the backend?
