March 24, 2023
I'm sending a lot of test envelopes which is using up the amount in my plan. Is there a way to test sending documents without using my plan amount? Thanks for any help!
With the Demo account, you will have the ability to send envelopes without using your envelope quota for your production account, once you have reached a satisfactory result for the template, then you can transfer your template to the production environment to be officially used.
There is no other option than use the Demo/Sandbox account.
March 24, 2023
You can create a Demo/Sandbox account, please see https://developers.docusign.com/platform/account/
March 24, 2023
Thank you Christopher,
I visited the site you suggested. I don't know if that is what I need. I'm working in Smartsheet to create templates to send through DocuSign. I have to send documents over and over until I can get the templates right which means I'm wasting envelopes so I was hoping there was another way to test my documents without using "real" envelopes.
Thanks!
