Thank you for reaching back.
In that case, the envelopes would have to be prepared one by one, if there is a document that is similar you can create a template and apply it to the envelope, that way the fields get automatically applied, and it decreases the preparation time: https://support.docusign.com/s/document-item?bundleId=gbo1643332197980&topicId=yav1578456266212.html&_LANG=enus
If you believe that you need further assistance, you can create a Customer Support case and a Tech Expert will be able to help. Please click the link below to open a Support case: https://support.docusign.com/en/contactSupport
If you’re not able to open a Customer Support case via the above link, you can scroll down the page to “More Support Options” and select "I can't reset my password or don't have an account." You will have different options to contact Support.
Back to Docusign.com
