Exceptions for required signatures
I need to work with a document that requires a signature based on the selected field. For example, if you are investing as an individual, you would fill out the relevant sections and sign in the designated area. If you are investing as a Trust, LLC, Corporation, etc., then you would fill in the appropriate field and sign. However, when I make the signature optional, I noticed that the prompt skips over the optional required signatures on the document.
May 30, 2024
@Sylvia.S99 - You can utilize Conditional Fields for this purpose. Depending on the selections made in other fields, new fields will appear. For more detailed information, please visit Conditional Fields (DocuSign).
May 30, 2024
Hi @Sylvia.S99,
