OCR post signatures - Optical Character Recognition
Some documents are not OCR’d when signatures are completed.  Odobe will not ODC documents post-signatures. If there a setting we can use to ensure documents are OCR enabled before signatures and, is there a process to OCR post-signatures?
Our documents are stored in SharePoint and being able to search the document text/content is important for our organization.
Thanks,
Mary
Hello @marymekk,
Are you sending the document via the Docusign Web App or are using an integration? If an integration is being used, can you provide the name?
Hi @marymekk,
