mshealy
Established Contributor
August 8, 2024
CLM workflow multiple signature in same position, should not be
  • August 8, 2024
  • 11 replies
  • 240 views
1. This workflow is putting both signatures in the same place, signature_1. How can i get this to put the second in /s2/ in the template?
template
workflow
signature 1 in correct place
document variable in esig for signatures
second signature.. putting on top of s1
Best answer by mshealy
Just talked with someone at DS, finally.  They said the functionality doesn’t allow you to have multiple send for signatures if you want the signatures on the same document because it will create a new envelope for each one, so i have to define all of the signers within one send for signatures.
August 8, 2024
@mshealy
I’ve seen this happen before.  Can you check the list of DocuSign Document Custom Fields on the eSign UI.   Check for duplicates with the same AutoPlace Text.   If this does not solve the issue, then delete and add a new one.   Make sure you don’t have duplicates.
mshealy
mshealyEstablished ContributorAuthor
August 8, 2024
This didn't work
Denise
August 8, 2024
@mshealy
Is it only happening between /s1/ and /s2/?  Are you also using /s3/ and /s4/?  Change /s2/ to another number like /s5/ in both the DocuSign esing UI and CLM documents.
mshealy
August 8, 2024
it happens for all signature.  they are all going to s1 position
Denise
mshealy
August 8, 2024
i have /s{r}/ in docusign esig.  are you wanting me to change it?
Denise
August 8, 2024
@mshealy
Using /s{r}/ in the AutoPlace Text is generally correct for dynamically placing signature fields based on text in the document. However, if all signatures are appearing in the same position, there might be an issue with the way the AutoPlace Text is configured or applied.
You could try to use /s1/ for the first signer, /s2/ for the second signer, and so on to see if that changes anything.
mshealy
August 8, 2024
that is what i have in my document.
Denise
mshealy
August 8, 2024
i ran it and it seems to be using 1 for the 1st, 2nd etc.  I am assuming that is why that is happening.  Not sure why its not incrementing.
Denise
mshealy
August 9, 2024
@JohnSantos It’s like it is resetting to 1 after each signature.
Denise
Pawan Gangwani
Hero
Hero
August 13, 2024
Hello @mshealy
if you are using the Auto place tag, are you defining the signing order in the “Send for Signature” step in workflow? this issue cause because of the recipient order.
