Radio buttons and conditional fields
  • July 17, 2024
  • 2 replies
  • 221 views
Am creating a HR template - it has one radio button Group - 3 radio buttons in the group.
Radio Buttons are named as:
Permanent,
Fixed Term
Casual.
On the form I have some fields not required to be filled in if Casual is the radio button selection ie I would like these fields not to be visible if Casual is the selected button, but visible for both Permanent and Fixed Term if they are the selected radio button
How can I set this up? (have been reading on Flag Fields/use of formulas, but can’t seem to get it to work, obviously missing something in my comprehension so far)
Best answer by Alexandre.Augusto
Hello, @Sue Chapman
You are welcome to the Docusign Community!
It’s possible to achieve what you want using Conditional fields.
Watch this video to learn how to do it:
Also, at Docusign University portal you can register for free trainings and webinar. There are Self-paced trainings too.
Here you can download a complete guide to create advanced templates including several examples regarding using Conditional fields:
https://dsucustomers.docusign.com/km-guide-building-advanced-templates-become-a-nigo-ninja-part-iv/1727389
I hope that helps, if so, I’d appreciate your Like!
Best,
Alexandre
Alexandre.Augusto
Hello, @Sue Chapman
Best,
Alexandre
Hi @Sue Chapman,
