Signing Groups with Same Users: How to ensure that the same user doesn't sign twice
  • October 10, 2024
  • 2 replies
  • 192 views
I have a process that requires two approval signatures, both from signing groups. The problem is that both of the groups will continue some of the same users. Is there a way to ensure that the same user doesn’t sign both times?
For example: Signing Group 1 contains users A, B, C, D and Signing Group 2 contains users A, B, C
If user A signs on the first signature line, is there a way to restrict it so that only users B or C could sign on the second line?
Thank you!
Best answer by Stephen.Whitaker
@Okitchen
First off, welcome to Community. So without knowing the full extent of your use case, a solution that you could possibly use is conditional routing for your form. The only thing is that conditional routing is not available in conjunction with a “Signature Field”. But you can use conditional routing with a “Drop-Down” or “check box” per say. So in example if you can a a drop-down field of the individual signers in the signer group, then you can add a conditional routing rule that says if “Signer A” was selected from the drop-down field then route the document to the rest of the group. The drawback is that you would have to create a rule for each person in the group. So this idea is best if the signing group members are low. It is a little bit of some front-end work and thinking a little out of the box, so to assist you, below is a link to our support site to provide some contextual information on conditional routing as well as a video to give a quick demo.
Link to support site:
https://support.docusign.com/s/document-item?language=en_US&bundleId=gav1643676262430&topicId=bhr1604354031124.html&_LANG=enus
Link to Video
I hope this provides you with some insight of the possibilities available to you, and do not hesitate to reach back out if you have any further questions.
Thanks,
Stephen Whitaker
Technical Product Trainer - Docusign University
Stephen.Whitaker
@Okitchen
Link to Video
Thanks,
Stephen Whitaker
Stephen Whitaker
Hi @Okitchen,
