December 14, 2022
How do you set up a document where an eSignature needs to tick an endorsed/not endorsed check box?
If checkboxes are not a good option for your use case, you might want to look into using radio buttons instead.
And, in case you are looking for your recipient to approve the document, instead of signing it, you can use our approve button.
You can find more details on how to work with radio and approve buttons, here:
https://support.docusign.com/s/document-item?bundleId=ulp1643236876813&topicId=vfk1578456408630.html&_LANG=enus
Let us know if you need further assistance with this
