How do I lock a template before using?
Hello! Wondering how I lock a template before using it?
I am wanting to lock the template e.g. a user will click “use template” , enter in sender/signer fields and then hit send straight away as opposed to editing the actual agreement template?
Hoping this makes sense, would greatly appreciate some advice on this!
Hi @Fran_ConsentLabs,
I understand that you are looking to prevent signers from editing your template, and I will share the steps to configure it.
You can restrict changes at both the recipient and template level, from their respective advanced options menu.
You can find detailed steps on how to lock your recipient roles or templates, here:
Protect a DocuSign Template From Changes
Template modification settings
To specify template modification settings
Recipient modification settings
To specify recipient modification settings
