Hi @ChrisBear !
Some DocuSign users have multiple DocuSign accounts. A common example is someone who has an account through work and another account for personal transactions. If you have multiple DocuSign accounts that reside on the same DocuSign site (e.g., NA1, NA2, EU), and they use the same email and password combination, then you can easily switch between them once you log in.
You can quickly switch between them in the account actions menu. Click your profile image > Select Switch Account > In the Select an Account dialog box, select the account to switch to.
This account switching is only available for same-site accounts using the same email and password combination, and only applies to active and suspended accounts. Inactive or closed accounts do not show up in the account drop-down. For accounts using the same email but existing on different sites, you can select which one to log in to.
To know if your accounts are located on the same site, please access Settings (you must be an administrator) > Plan and Billing.
If you’re looking for a live customer support assistance, you can open a case with Customer Support or call them directly (access More Support Options > I can’t reset my password or don’t have an account > select eSignature product > click on “You can also call us for help”.
https://support.docusign.com/s/contactSupport?language=en_US
