HELP! Require Recipients to Draw Each Signature
  • October 24, 2024
  • 2 replies
  • 190 views
I am the admin of the account and we our plan is eSignature Business Pro - but I do not have the Signature Adoption Configuration option to set up the requirement for a “drawn signature”
Can anyone help me about why this option seems to not be available?
If you’re the Admin for your account [i am], go to the Settings page then Signing Settings [i have] and configure the Signature Adoption configuration [i dont have this] , you can enable the option for drawn eSignatures [nope]. After that, your envelopes sent to the recipients with Sign Here fields will give to them an option to drawn a signature [nope].
Best answer by Christopher.Alpizar
Hello @AlexL,
Per the community guidelines (https://community.docusign.com/site/terms) we can only provide you with general information, the Account Admin will need to contact Support directly for Billing Inquiries, Account Change Requests, or Feature enablement. Your plan should have the Signature Adoption Configuration enabled, you will need to open a Support case and have the Support agent review the account configuration at the backend. To open a support case in the Docusign Support Center, go to the "Get Support" section and select "Open a Support Case". Log in using your Docusign credentials and select a case subject. If you have multiple Docusign accounts, choose the appropriate account to continue. Open a case in the Docusign Support Center.
Hello @AlexL,
Hi @AlexL,
