Envelope ID Stamp Control is supported by Business Pro For Salesforce?
I’m been trying to find a solution to remove or replace the envelope Id from my templates. I found that it is possible with the Envelope Id Stamp Control, but I want to know if it is available for Business Pro For Salesforce?
Alexandre.Augusto
Hello, @vanesys
Go to your Settings page, verify if you have the options below in the Sending Settings:
Now, with this setting enable you can place it where you would like.
See this article:
https://support.docusign.com/s/document-item?language=en_US&bundleId=gbo1643332197980&topicId=iuo1578456366911.html&_LANG=enus
If you don’t see that setting in your account, contact our Support team to help you with this request.
Best,
Alexandre
Alexandre.Augusto
Hello, @vanesys
See this article:
Best,
Alexandre
Derrick.Tran
Hello @vanesys,
In addition to @Alexandre.Augusto response, this setting would not retroactively update existing templates with this setting. You would have to update each template individually with the following Step.
Hi @vanesys,
