Change body of email sent by Power Automate
  • August 8, 2024
  • 2 replies
  • 407 views
Hi, I am using a Microsoft Power Automate flow to generate a document, create a Docusign envelope, attach recipients and tabs for their signatures, and send it. I have 3 recipients set in a signing order. I have custom email bodies requesting they review and sign the document.
My issue is this - when the envelope is completed, Docusign sends an email automatically. The body starts with ‘All parties have completed [document name], but the text from the original email remains. The only link to the document is to review the completed version, but to mitigate any confusion, I want to remove the original email body (the request to sign) from the completion notification email.
I’m looking for a solution that either: can remove the original email body from the ‘completed’ email or turns off the ‘completed’ email notification, so I can send it through Power Automate with custom text.
Thanks!
Best answer by Alejandro.Ramos
Hi @emhaya,
You can manage your default email templates as part of your account branding configuration in Settings>Branding>Email Custom File. For detailed steps on the available notification templates, see:
DocuSign Email Resource File Guide
Note: Some advanced features and options are supported only in certain Docusign plans. Your account plan might not support some of the options discussed in this help topic. Contact your account administrator for more information about which options are available for your account. Or, visit our Plans and Pricing web page for more details on the features included with your plan.
Feel free to let us know if you need further assistance with this. Thank you for using Docusign, we hope you have a wonderful rest of your day!
Hi @emhaya,
​Hi @emhaya,
