Is there a phone number I can call for issues?
I appreciate you sharing your concern. You may contact DocuSign Support at 1 (800) 379-9973.
Or, you are always welcome to create a case and have a Support Expert take a closer look at your issue.
If you are not able to open the case on the same page, you should scroll down to More Support Options and select "I can't reset my password or don't have an account." you will have the option of filling out the form or calling Support.
When filling in a form and using the Signer Blocks, I need to be able to see the completed doc with the Signer Blocks before sending. It looks like if I hit “Correcting” I can do that but it doesn’t make sense to say I’m correcting the doc when I’m not--just need to see the signer blocks to be sure it’s sending properly.
Thank you.
Reply
Sign up
You can login or register as either a Docusign customer or developer. If you don’t already have a Docusign customer or developer account, you can create one for free when registering.
Customer Login/Registration Developer Login/RegistrationDocusign Community
Customer Login/Registration Developer Login/RegistrationEnter your E-mail address. We'll send you an e-mail with instructions to reset your password.
