Webform - return to originator to edit for resubmission
  • 23 July 2024
  • 2 replies
  • 14 views
Is it possible to set a Webform (or Powerform) to return a form the originator to edit/update if rejected at any point during the sign-off process? The updated form would then bere-subitted for approval.
Userlevel 4
Badge +12
Hi @blusamis,
I understand that you are looking to allow your signers to decline to sign your document without voiding your envelope, and I will share more details on the topic.
Any signer that declines to sign an envelope will cause it to be voided by default, there is no way to work around this behavior. However, you could look into using our Collaborative Fields/ Mark up feature, that will allow the recipients collaboration in the envelope, and will trigger the signing order to be restarted if there are any changes made to the document. You can find detailed steps on how to work with this feature, here:
Set up a Collaborative Field
Thank you for using Docusign, we hope you have a wonderful rest of your day!
Userlevel 4
Badge +12
Hi @blusamis,
I would like to confirm if you were able to solve your issue by utilizing the solution that was suggested?  If so, please mark it as the best answer by clicking “Select as Best” to make it easier for other users to find. Otherwise, feel free to let me know and I will gladly help you address the situation as soon as possible.
Reply
