problem with identify
  • August 29, 2024
  • 2 replies
  • 127 views
Hi! I was trying to complet the last step in signing the contract and I I needed to confirm my identity. I choose to do it via Bank ID, but the problem is that in my contact it’s my full name including middle name, in my Bank ID I only have my first and last name. And because of that I can’t confirm my identity because it’s different from my contract. How should I do?
Best answer by nathaly.monge
Hello @Norakemi ,
There is only 2 options:
  • Contact the sender of the envelope and request them to change the document to match you ID.
  • Or change the ID to one that matches the name in the envelope.
I recommend you contact the Sender.
Hello @Norakemi ,
Hello @Norakemi ,
