Need help
Hello, I need help for sending envelope for many recipients.
I use 1 template for 30 recipients, but I can’t add fields for everyone. How can I add field for every recipient? When I send I have a window “Missing field for recipients”.
April 18, 2024
@Erka - If these are signing recipients, they would need at least one field assigned to them.   If they are not acting on the envelope and you just want them to receive a copy, assign them the role of “Receives a Copy”.
April 18, 2024
Hello @Erka ,
