How to configure Automated phone call for recipients without cellular phone ?
For recipients without cellular phone, ‘Automated phone call option’ is mentioned on Docusign support web page :
https://support.docusign.com/s/document-item?language=fr&rsc_301=&bundleId=gav1643676262430&topicId=rzi1578456523624.html&_LANG=frfr
What is procedure to configure such option for a recipient living in Canada ?
Thanks
Alexandre.Augusto
Hello, @Hugues
SMS and Phone Authentication is an Add-On accordingly an account plan.
I suggest to you contact our Sales team asking about it.
After be enabled in the account, you will see this setting:
Sales team in USA can be contact by phone:
1 (877) 720-2040
Or using this link:
https://t.ly/XS98I
I hope that helps!
Alexandre
Alexandre.Augusto
Hello, @Hugues
1 (877) 720-2040
Or using this link:
https://t.ly/XS98I
I hope that helps!
Alexandre
Hi @Hugues,
