LauraMU
Help with formula field
  • July 31, 2024
  • 2 replies
  • 136 views
Hi Community,
I have a document in which vacations are requested, and people must add the dates, from - to. There are 2 text fields added with a date format.
I would like to know if there is a way with a formula, to take the number of days chosen, for example, if I choose from Monday to Wednesday, that field returns the number 3.
Thanks in advance for your help! :)
Best answer by Michael.Rave
@LauraMU
You can leverage the DateDiff() formula, which will return you the difference between two date fields.
I think you need to add an additional day to include the last day. Therefore, the formula should be:
DateDiff([EndDate],[StartDate])+1
→ EndData and StartDate are the two data labels of the text fields, simply modify to your data labels.
You can find more information on date formulas in this Docusign Support article.
Michael.Rave
@LauraMU
​Hi @LauraMU,
