Hi!
We contracted the Docusign ID Verification to validate the face and document of our signatures.
I opened a case in October/2023 and since then I have no response anymore. They know the problem exists but don't fix it.
Any ideas? The first trials the verification entered a loop and now it takes 3 minutes to validate a face, which is ridiculous.
Hi @Bruno Gabriel ,
I’m sorry to hear you about your unfortunate experience with support, I understand you are having issue with the ID verification method provided.
To better understand your issue, can you provide more details?
  • Are they getting any type of error?
  • Does the loop end in an error?
  • By any chance do you have the case number?
Hello @Bruno Gabriel ,
Were you able to provide the information that I previously requested? If so, please do so in a reply to this question so that I am able to further assist you with your issue.
"Select as Best" below if you find the answer a valid solution to your issue
I understand your frustration with DocuSign's ID verification. It can be a real headache when things don't work as expected, especially when you're in the middle of something important. I had a similar experience where I tried everything, but it wouldn't go through smoothly. It made me look for alternatives, and that's when I found idanalyzer.com . Honestly, it was a game-changer for me. The process was straightforward, and I didn't have to jump through hoops. You might find it worth a shot if you're open to trying something different. Sometimes, finding the right tool can make all the difference!
Reply
