Web form field not pushing data to template when executed
Userlevel 2
Badge +3
I have a field on my webform call Source of Alternative Qualifications  See below:
Here is the connection:
Here is the field on the template, under Terminal Degree
When i fill in the web form, the data does not go to the template after submitted.
If someone sees something wrong, please let me know.
Thanks
Denise
Userlevel 4
Badge +11
Hello @mshealy ,
I’m sorry to hear that your prefill fields are not working accordingly, I understand you need the information inputted in the Web Form to be sent to the actual document the recipient is going to sign, is that correct?
If so, I recommend you edit the checkbox labels to something easier to identify and input the values of each option as shown in the following article: Prefill a Web Form
Badge
 When a web form field fails to push data to a template upon execution, several factors may be at play.  High Speed Internet Provider Check the data binding configuration to ensure proper linkage between the form field and template. Additionally, verify that the form submission triggers the intended action and that any server-side processing or database interactions occur as expected. Debugging the backend logic and frontend scripting can help pinpoint and resolve the issue efficiently.
Userlevel 4
Badge +11
Hello @mshealy ,
Reply
