Initially when i have login i was able to create web forms now i am not able to see them why ?
  • 15 March 2024
  • 2 replies
  • 18 views
Badge
I am not able to see webforms now  in my account
Userlevel 4
Badge +11
Hi @ritika !
There are some possibilities why you are no longer seeing the webforms function in your account:
  • The first thing is to know if you have made any changes to your account plan. The WebForms feature is not available on all plans, so this could be the cause. To know this, you need to be an Account Administrator and access Settings (menu) > Plan and Billing.
  • Another possibility is that your account administrator changed your access profile, removing permission to use WebForms. In this case, it would be necessary to contact the administrator to check this information.
Userlevel 3
Badge +11
Hi @ritika,
Reply
