Problem with one field in Bulk Send
  • October 8, 2024
  • 5 replies
  • 129 views
I have uploaded my CSV file using the CSV template.  I’ve left some fields empty because I don’t know what they are for.  But one field - Requestor::First Name is not coming through and even though I accept the matching exception, I end up with an error message after I do. The names in the First Name column match the first names that are also included in the Name column...not sure what I am missing.
Best answer by nathaly.monge
Hello @NStephen ,
Was the CSV created by you? Can you try downloading the sample CSV? If you are using the sample CSV, can you try changing Requester::First Name to Requester::Name?: Generate a Customized CSV File for the Bulk Recipient List
Hello @NStephen ,
Hello @NStephen ,
Are you able to provide the information that I previously requested? If so, please do so in a reply to this question so that I am able to further assist you with your issue.
NStephenNewcomerAuthor
Hello.  Your recommendation got me past the error message.  However, I later found an anomaly that is causing some of the recipients not to be able to add their last name.  🤔Something to figure out for the future...
Hello @NStephen ,
Thank you for reaching back.
Are they getting an error? Can you provide more detail on what they are experiencing?
Hello @NStephen ,
