For recipients without cellular phone, ‘Automated phone call option’ is mentioned on Docusign support web page :
What is procedure to configure such option for a recipient living in Canada ?
Thanks
Thanks
SMS and Phone Authentication is an Add-On accordingly an account plan.
I suggest to you contact our Sales team asking about it.
After be enabled in the account, you will see this setting:
Sales team in USA can be contact by phone:
Or using this link:
I hope that helps!
Alexandre
Hi
Enter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
