I am not able to see webforms now in my account
Hi
There are some possibilities why you are no longer seeing the webforms function in your account:
- The first thing is to know if you have made any changes to your account plan. The WebForms feature is not available on all plans, so this could be the cause. To know this, you need to be an Account Administrator and access Settings (menu) > Plan and Billing.
- Another possibility is that your account administrator changed your access profile, removing permission to use WebForms. In this case, it would be necessary to contact the administrator to check this information.
Hi
Christopher | DocuSign Community Moderator
Reply
Sign up
DocuSign Community
Ask and answer questions, join groups and grow together.
Customer Login Developer LoginEnter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
