Delivered
Signing is only half of the problem
Categories:eSignature
I just (today at 4:20pm) had to sign a document. One of the options was to SELECT a given font and use that. One of the options was to DRAW your signature. (Which would be gibberish if I did that.) One of the options was to UPLOAD your signature.
Now - before I go on - I might have had to upload just my initials AND THEN upload on my signature - BUT THERE WAS NOTHING TO TELL ME THIS. Instead on the initials it would only let me upload initials. So, being a logical person I was going “Hey! Why can’t I upload my full signature?”.
Because of the above, I was very confused and then opted for a different font and signed the document that way.
So my suggestion/idea is to not just do one part of the initial/signature but to do both of them AT THE SAME TIME so you do not confuse people. OR - you could just put a link to the other half of the equation. I.E. : If you are on the INITIAL part - have a link to change the person’s signature and if you are on the SIGNATURE part have a link to the initial part.
Basically, it is not enough to only do part of what is needed - you should always do the entire part. In this way you eliminate the confusion and everyone benefits from going the entire way.
Thank you for reading this.
Hengfeng Ge
Hero
Hero
December 13, 2024
are you create signature when you sign the envelope or create signature in my profile?
it support upload both signature and initials when you create signature in my profile:
and the document also told  Upload your own signature and initials image files.
https://support.docusign.com/s/articles/How-do-I-change-my-signature-or-adopt-a-custom-signature-NDSE?language=en_US
  1. Enter your name and initials exactly as you want them to appear in your signature, then select one of the following options:
  • CHOOSE: Select any of the pre-formatted signature styles.
  • DRAW: Create a freehand drawing of your signature and initials.
  • UPLOAD: Upload your own signature and initials image files.
FreeLink/甫连信息
🌍 Docusign Partner | Partner Profile
🏆 Docusign 2024 APAC Reseller Growth Partner of the Year
🌟 The only Docusign Partner globally certified as both a Certified eSignature Administrator and eSignature Technical Consultant.
📊 Docusign Community Leaderboard Top 5 contributor.
🚀 Expertise in Docusign integrations with on-premises systems for leading enterprises across various industries.
​@markem , we’re thrilled to share that this idea has been delivered!
Thank you for your feedback—it played a big role in shaping this feature.
You can learn more about how to use it Change Your Signature, and we’d love to hear what you think!
Change your signature or adopt a custom signature
Please take note that the sender can sometimes restrict these options.
If you can't, you'd need to contact the sender to add an initial field or use the "Print & Sign" option to print, initial on paper, and scan back
Idea Submitted→Delivered
