Aug 13, 2024 5:33 AM UTC
Envelope expiration notification for Sender
Hi, as the Sender of an envelope is it possible to set a notification to be automatically received when an envelope is due to expire? I’m aware that notifications can be set for a recipient to receive a pending expiration however I can’t locate any settings for the Sender. Currently the Sender is required to access DocuSign on a daily basis to check for any voided envelopes.
Pawan Gangwani
Hero
Aug 13, 2024 7:50 AM UTC
Hello @MattyF
I am not sure about pushing notification to the sender for due expiration date of envelope but if you are looking to set the automatic notification to send out to sender when any recipient decline to sign then there is a way.
You need to navigate on “Profile” icon and click on “My preferences” and you will the “Notification” option in left hand side panel where you can set the notifications for sender.
Here is the link of support article for more information: Manage Sender Notification
Thanks!
Pawan Gangwani
Hero
Hero
Hello @MattyF
Thanks!
Aug 27, 2024 10:54 PM UTC
Hi @MattyF,
Oct 8, 2024 5:07 PM UTC
Hi -- this does not solve the issue from what I can tell.
There should definitely be a way to warn the Sender that a document is about to be expire and be voided.
Some documents require MANY signatures, which can take a very long time occasionally.  Not sure why all the Recipients would be notified, but not the Sender.  The Sender is the one who has to start all over again gathering signatures.   I have changed the expiration on the account via Admin to 999 days.  This should help.  But really -- the Sender should be notified of any documents that are expiring and about to be voided.
Thanks.  Joleen
Oct 9, 2024 10:45 PM UTC
Hello @Joleen Sanborn,
I apologize for any inconvenience this might cause you, any feedback that can improve our users’ experience is always welcome.
We invite you to share your product suggestions and feature requests on our dedicated ideas page (https://community.docusign.com/ideas), where we can collaborate to shape the future of our product together.
Feb 21, 2025 2:14 AM UTC
We have ours set at 100 days. I am the sender and get the notification in less than 24 hours from sending out. How do I stop them for me (the sender).
