Feb 12, 2026 7:43 PM UTC
Why is 'radio button' input field locked?
I want to use radio buttons in my template.  However, the input for radio buttons (as well as numbers, drop downs and several others) are locked.  Why are these locked?  How do I insert radio buttons?
Feb 13, 2026 9:29 PM UTC
Hello ​@stmark,
Thanks for reaching out and welcome to the Docusign Community!
If radio buttons, number fields, or dropdowns are showing as locked, it usually means those features aren’t included in your current DocuSign plan.
Could you let me know which plan you’re using? That’ll help me check whether these fields should be available to you.
Happy to help!
Best Regards,
Feb 21, 2026 4:40 AM UTC
Hello ​@stmark,
