Aug 6, 2026 6:28 PM UTC
What is easiest way to search for old documents? Nothing I try seems to work
How can i search for old envelopes? It is frustrating
Digital Leader
Aug 6, 2026 7:25 PM UTC
​@HiltonM1
Search can be a bit hit-or-miss.
I usually search in “All Agreements” unless I know I’m looking for a “completed” or “in progress” envelope.
There are a few filters “on” by default. Check the space to the right of the search box and “x” out these defaults. Then add in any filters you need via the dropdown boxes, and enter your search terms.
Occasionally, I just restart the search (especially if I KNOW what I’m looking for exists, even if it’s not coming up in the results).
Good luck!
mr1
MR1
Aug 17, 2026 1:23 PM UTC
Hi ​@HiltonM1,
I hope you’re doing well and having a great day!
I wanted to see how things are going on your end. If there’s anything else you need or if there’s any way we can further assist, please don’t hesitate to let us know. We’d be more than happy to help.
