Feb 25, 2026 3:30 PM UTC
Require recipient to draw in a document we send
do you know if there is a possibility of sending a document to someone to sign and draw in the document? we are developing a car report and the person that receives the document must sign and draw in the document where are the damages in the car.
Ma.CubioAnswer
Mar 5, 2026 2:33 PM UTC
Hello ​@Gabriela from Wanted
There is a field here in Docusign called the Drawing field. In the Drawing field, you can specify areas in a document for a signer to add a free-form drawing. Your signer uses a simple online pen tool to draw lines and shapes in six basic colors anywhere within the dimensions of the field. Your signer can draw on your document, or you can include an option for them to upload their own image to draw on.
Note: Some advanced features and options are supported only in certain Docusign plans. Your account plan might not support some options discussed in this help topic. For more information about which options are available for your account, contact your account administrator or Docusign Customer Support. Visit our Contact Support web page for contact options to reach Customer Support.
Related article.
Drawing Fields
Feb 25, 2026 7:19 PM UTC
Yes — this is absolutely possible in DocuSign.  Part of the Standard Fields in your envelope is a Drawing tool.
Related article.
Drawing Fields
Mar 12, 2026 9:51 PM UTC
If you found the response to be a valuable solution to your question, please “like” and mark it as the best answer by clicking “Select as Best” to make it easier for other users to find. Thank you!
