Jul 31, 2026 8:52 PM UTC
Generate Document without envelope ID
I would like to check if Docusign can generate the Documents without the envelope IDs. Our firm (ASCAP One) is using ‘Enterprise Pro For Salesforce’ Plan. Thank you.
Naga Chaitanya Yepuri
Aug 3, 2026 5:15 PM UTC
Hello Naga Chaitanya Yepuri,
Yes, this is possible. If you're a DocuSign administrator, you can enable the setting that allows senders to choose whether to include the Envelope ID on their documents.
To do this: go to Admin → Sending Settings → select "Enable including the Envelop ID on the document"
Once enabled, senders can choose whether to include the Envelope ID when creating an envelope by clicking the gear icon/Advanced Options in the upper-right corner, selecting Sending Settings, and unchecking "Show Envelope ID on all document pages."
👉 Send a Document Without the Envelope ID on It
The ability to control Envelope ID placement is available on paid DocuSign plans, including Enterprise plans.
I hope this helps! If you believe this response effectively addresses your question, mark it as “Best Answer”.  Let us know if you have any further questions
Best Regards,
ncyepuriNewcomerAuthor
Aug 3, 2026 9:16 PM UTC
Thank you for the prompt response, the options are currently greyed out for us. Do we need to reach out to someone to enable this? Really appreciate your time and support.
Thanks again!
Aug 3, 2026 9:39 PM UTC
Hello ​@ncyepuri,
Yes, a backend setting needs to be enabled by support to make the option clickable and not grayed out.
Please open a support case and request that Envelope ID stamp control be enabled. 👉 Get Support
Best Regards,
Aug 10, 2026 10:34 PM UTC
Hello ​@ncyepuri,
We trust that all is well. We’d like to know if the suggested solution was helpful. If yes, we would greatly appreciate it if you could mark it as "Best Answer", to help other community members find trusted answers.
Let us know if you need further assistance. We’re here for you!
Best Regards,
