Jul 2, 2025 10:22 AM UTC
frame number for signature
How do I get the frame number around my signature? I have the personal plan
Pawan Gangwani
Hero
Jul 2, 2025 11:13 AM UTC
Hello ​@Gilly73
Just to clarify are you referring to this kind of number around your signature?
If yes, navigate to the 'Admin' section, then go to Signing and Sending > Signing Settings. There, you'll find the option to enable this feature. However, please note that availability may vary depending on your plan, as features differ across subscription levels.
Thanks!
Pawan Gangwani
Hero
Hero
Hello ​@Gilly73
Thanks!
Jul 10, 2025 11:39 PM UTC
Hello ​@Gilly73,
I hope you’re doing well. I'm following up on the above solution provided. Could you please confirm whether it addressed your question? If it did, can you please mark it as Best Answer ✅" to assist other users with similar inquiries and improve its visibility. Let us know if we can help with anything else. Wishing you a smooth rest of your day!
