Apr 22, 2026 8:15 AM UTC
Envelope Management
The Live Chat doesn’t do anything when I click on it!
Anyway, it appears that documents are retained in DS indefinitely, is that correct?
From a GDPR point of view, when we no longer deal with a client, we need to remove any documents pertaining to them, that’s fine from an individual user point of view but we have many users who may have sent an envelope to a particular client - is there a way that an administrator can search all documents without having to go into each user’s account individually?
May 1, 2026 3:30 PM UTC
Hi ​@ElspethB,
I hope you’re doing great. I would like to check if the information provided helped.
Feel free to click the “Best Answer ✅” button below the post. That helps others in the Community find trusted answers faster.
Thanks for being part of the Docusign Community!
Apr 23, 2026 1:36 PM UTC
Hi ​@ElspethB,
We appreciate you reaching out to the Docusign Community and are delighted to have you join us.
I’m sorry to hear about your concern regarding managing envelopes across all users in the account. I understand how important it is to track down envelopes sent to clients you are no longer working with and take care of any related documents.
An admin can utilize the reporting feature to locate envelopes associated with a specific recipient. By generating an Envelope Report, you can filter results by recipient name or email address, sender, date range, and status. This allows the admin to identify which user sent the envelope without needing to access each account individually. Once the report has been generated, you can export the data as a CSV file for easier review and tracking.
Kindly refer to this article for more information:
Envelope Report
Envelope Recipient Report
If you need anything else or have more questions, feel free to reach out. I’m happy to help.
If this helps, feel free to Like👍and click "Best Answer."
ElspethBNew VoiceAuthor
Apr 23, 2026 1:57 PM UTC
Thanks a lot Noralynn - that’s really helpful.
Regards.
Elspeth
Apr 23, 2026 2:12 PM UTC
Hi ​@ElspethB,
I appreciate your response.
If anything else comes up or you hit another roadblock, don’t hesitate to reach out here in the Community.
Wishing you a smooth rest of your day! 🌞
If this helped, feel free to mark it as "Best Answer" so others can find it too!
Apr 24, 2026 12:44 PM UTC
Good afternoon, a further query, if I may please.
We clearly need to get into a habit of regularly deleting documents that we have dealt with but, in the meantime, is there any way that an administrator can bulk delete items for a) either themselves in relation to one or more clients, or b) on behalf of the team?
Also, is there a facility whereby we can set up an automatic deletion after, say, 2 months?
Thanks a lot.
Apr 24, 2026 1:56 PM UTC
Hi again ​@ElspethB,
Thank you for getting back to me.
If I understand it correctly, you would like to bulk-delete envelopes or documents at the user level or on behalf of another user. Also, looking for an option to set automatic deletion for a specific period. I’m happy to help! 🙂
On a user level or as the sender, they can try the following steps to do a bulk envelope deletion:
1. Go to Agreements > All Agreements
2. Use the Date filter to customize the start and end date
3. Select envelopes for deletion
4. Click on the 3 dots on top (beside the Move button), then click Delete
Please take a look at the image below for guidance.
Link for reference: Delete Envelopes
An admin can set up Shared Access to users and grant permission where the other user can void envelopes on behalf of another user. Please take a look at how the Shared Access works, and its permission through this article: Shared Access to Envelopes
Regarding the automatic envelope deletion, Docusign offers a Document Retention Policy, which allows an admin to set the number of days to retain completed, declined, and voided documents. Setting a document retention period is optional. By default, Docusign securely retains all customer documents on the service for as long as the account is active.
For more information, kindly refer to this article: Set Document Retention Periods
If you have set up document retention in the account, please take note that documents will no longer be retrievable from Docusign once deleted. To ensure continued access to important documents, we recommend downloading and securely storing completed envelopes outside of Docusign.
I hope this is helpful! Feel free to reach out if you have any questions or clarifications.
Apr 24, 2026 3:06 PM UTC
Thanks again Noralynn, I shall take a look at that next week.
Have a good weekend.
Elspeth
Hi ​@ElspethB,
