Aug 27, 2026 7:23 AM UTC
Document steps through approval stages; then needs an addition, then further signatures; then addition edit; then final signatures
The question relates to a Management of Change Request and Approval Document. It steps through 21 numbered sections in order. Once a section is signed it is completed but there are subsequent sections requiring minimal entry then the document progresses to the next
  • section 5 and 6 need to be signed and dated by 2 separate individuals
  • then later section 7 has an event date added (I’ll probably sign that as well)
  • section 17 has a group of stakeholders (including two of the previous signatories) review the proposal, sign on the progress to date and accept/reject the proposal
  • Section 18 is authorisation to implement the change based on the recommendation/acceptance from section17
  • section 19 subsequently has 3 dates added to existing fields
  • section 21 is post change review whixch is completed, signed and dated by yet another signatory
  • Completed
Thankfuk for any assistance.
Regards
Darryl
Ma.CubioAnswer
Aug 31, 2026 3:36 PM UTC
Hello ​@darrylprice
Thank you for reaching out, and welcome to the Docusign Community! Thank you for providing your detailed workflow. Following the process you have sorted out, we can configure all steps using a single envelope and enable the signing order function. You can assign each chapter of the document directly to the corresponding person in charge and precisely control when each participant can access it, so there is no risk of the workflow falling into disarray.
An example of a practical assignment will make this clear to you: Section 5 and Section 6 of the document can be assigned to two different signers; Section 17 can be sent to all relevant personnel who must participate; Section 18 can be forwarded to the person responsible for approval and authorization; Section 21 can be handed over to the person who performs the final closing review. If multiple relevant personnel need to handle their respective tasks independently, without waiting for the previous person to finish before they can start, even if the overall Signing Order has already been set, we can still send the document to these people at the same time,  that is, follow a parallel forwarding workflow, so they do not have to wait in a queue one after another.
For some types of information that cannot be filled in at the very beginning, they can only be supplemented and completed at a later stage of the process. For example, the date that needs to be filled in Section 19 falls into this category. For content that requires delayed supplementary filling, it is best to assign the corresponding reserved filling fields directly to the contact person who will take over and fill in this content later, when the entire process is initially built, rather than making temporary arrangements only when it is time to fill in the information.
One important consideration is that Correct is intended for in-progress envelopes and should not be used to modify actions or information associated with recipients who have already completed their part. If the process requires reopening and modifying previously completed sections, a different workflow or multiple envelopes may be more appropriate.
If you wish to refer to more relevant content, you can view the guidance document on these articles.
Set a Signing Order
Correct Envelopes
Envelope Template Recipient Actions
Hello ​@darrylprice
Set a Signing Order
Correct Envelopes
Sep 8, 2026 12:52 PM UTC
Hello ​@darrylprice
How are you? We'd like to know if my previous response addressed your questions. If so, we hope you could consider selecting it as Best Answer ✅," so others can find it too.
Otherwise, if you still require further assistance, please don't hesitate to let us know. We are always happy to help!
