Leah Breen
September 15, 2025
September Developer Ask Me Anything (AMA): Building and automating agreement workflows with Docusign APIs
  • September 15, 2025
  • 14 replies
  • 1342 views
👋 Hey developers! Tired of hard-coding agreement flows over and over?
September’s developer AMA is all about automating workflows with Docusign. The thread is open now through September 30—ask your questions async-style and get answers from Niani Byrd, programmer writer at Docusign who brings her perspective as a full stack engineer.
When you comment with a question, you’ll also be automatically entered into a giveaway to choose a $100 gift 🎁
🔧 Topic for this AMA: Building and automating agreement workflows
Manually routing agreements and stitching together custom code can slow your apps down and frustrate users. With Docusign Workflow Builder (formerly Maestro), you can:
  • Automate every step of an agreement—data collection, routing, signing, and post-sign actions—in one flow
  • Orchestrate across eSignature, CLM, IDV, and extension apps without writing brittle custom code
  • Standardize agreement processes with reusable templates that enforce compliance
  • Add conditional routing and decision logic to reflect real-world complexity
If you’ve been trying to reduce custom code, speed up build time, or connect multiple systems into one seamless workflow, this AMA is for you.
🧠 Ask Niani about:
  • Orchestrating workflows programmatically with the Workflow Builder (formerly Maestro) API (trigger, monitor, pass inputs)
  • Embedding and triggering workflows directly from your app
  • Identity verification flows and fallback logic when verification fails
  • Conditional logic and branching to cover multiple agreement paths
  • Building reliable end-to-end workflow patterns (e.g., form → template → signing → CRM update)
💡 Not sure what to ask? Try these:
  • When should I use Workflow Builder (formerly Maestro) instead of building workflows myself or writing my own routing logic??
  • How do I trigger a Workflow Builder (formerly Maestro) workflow from my app using the API?
  • What’s the best way to connect Workflow Builder (formerly Maestro) with Salesforce or Dynamics?
  • How can I build conditional routes for when identity verification fails?
  • What’s a good pattern for automating form → signing → CRM updates?
💬 How to participate:
  • Drop your questions in the comments through September 30 and tag @niani.byrd
  • Niani will reply directly in the thread
  • No question is too small—this is a space to learn!
🎁 Bonus! Comment in the AMA thread and you’ll be automatically entered into a drawing to win a $100 Loop & Tie gift. You’ll get to choose from a curated collection—think artisan coffee bundles, cozy alpaca throws, and more—delivered to your door. Replies must be relevant to the AMA topic to be eligible. Off-topic questions may be moved by moderators. Terms & conditions here.
📌 Reminder:
This AMA is for general questions about Docusign’s APIs and implementation best practices. For account-specific issues, reach out to Support. For feature requests, drop them in the Ideas section.
Let’s build smarter workflows—ask away 👇
This topic has been closed for replies.
niani.byrd
Hi everyone!
I’m looking forward to your questions and diving into the world of building and automating agreement workflows! 🚀
Here are some helpful resources on the topic to kick things off:
Conversation Starter
September 17, 2025
2 questions - Authentication - is this Docusign authentication or can this be linked with SSO type authentication?  Can data be passed through from from IDM/Authenticaton?  if not what other systems?
niani.byrd
Hi ​@Norma Clark! Maestro uses OAuth 2.0 for authentication. Check this resource out for more information on authentication. At the account level, Docusign can integrate with your SSO for user login, but Maestro does not automatically pass identity data from your IDM/Authentication into workflows. If you need to use attributes from your IDM system (like email, employee ID, or group), you can capture those after login and pass them into Maestro as workflow input variables. Maestro can also accept data from systems like CLM, Power Automate, or an extension app via the Maestro API. This is a helpful resource that will provide more information on passing data to workflow variables.
Thanks for your question!
Active Voice
September 18, 2025
​@niani.byrd
When triggering Maestro workflows from our app, what’s the best way to avoid duplicate runs and keep track of which workflow belongs to which user action?
For example, should we use webhooks or polling to check status, and what’s the best way to pass a correlation ID so we can safely retry if something fails?
niani.byrd
​@niani.byrd
Hey there ​@Vas!
To avoid duplicate workflow runs, generate a correlation ID for each user action (for example, order-1234) and include it as a starting variable when triggering the Maestro workflow. Store a local mapping of {correlationId → workflowInstanceId} in your database, so that if a retry occurs, you can check whether a workflow has already been created for that action. Check out more information here on starting variables.
For tracking status, webhooks through Docusign Connect are the recommended approach over polling. Subscribing to workflow events such as workflow-started or workflow-completed will give you real-time updates, and Connect will handle delivery and automatic retries to ensure those updates reach your system. Here’s a helpful resource on monitoring workflows.
Great question!
​@niani.byrd Hey there! I was wondering if DocuSign provides the ability for programmatically signing a document (via an API, maybe). The scenario is that we have a contract that needs to be signed on behalf of our company as well as by the client who receives the contract. It would be great if we could automate the signing on our behalf and just send it to the recipient for signing. Is this possible? If not, are there any alternatives? Thanks!
niani.byrd
Hi ​@faheemkodi!
Unfortunately, automatic signing of a document through the API is not possible in Docusign because each signature requires a signer to complete the signing ceremony. If your company is required to sign, one option is to use a Docusign electronic seal (eSeal), which can be applied programmatically to certify the document on behalf of the organization. Here’s a technical blog that goes into deeper detail on using a Docusign eSeal for your documents. If an eSeal is not appropriate, you can prepopulate fields with your company’s information before sending. This does not eliminate the need for a company signature, but it does simplify the process by reducing what must be filled in manually before the envelope is signed and routed to the client.
Pau123
Active Voice
Active Voice
September 27, 2025
Hi ​@niani.byrd, I have one, possibly two, questions: What resilience patterns does Maestro support or recommend for transient downstream failures (retry, circuit breaker, backoff, DLQs), and how should those parameters be scoped per step vs. platform-wide defaults?
Hi, I’m working on an integration between Make.com and DocuSign.
In my scenario, I already have everything set up (Google Sheets → Google Drive → Google Docs → DocuSign). The last step is where I’m stuck:
I want to use a DocuSign template for the recipient roles and signing fields, but instead of using the template’s default document, I’d like to replace that document with another one (a lease generated earlier in the flow).
Can you help me figure out how to set this up in Make.com? Also, please let me know if I should explain my setup in more detail.
niani.byrd
Hey ​@Pau123!
Maestro performs internal retries within most step implementations to help handle transient issues, and when a step surfaces an error it has typically already retried multiple times behind the scenes. Building on this, a new capability is coming in the next few months that will let users manually retry an instance from a particular step, giving you more direct control over recovery without having to restart the entire workflow. While Maestro does not include automated patterns like circuit breakers or dead-letter queues today, it does provide tools to pause, resume, and check the status of workflow instances. In addition, Docusign currently provides a retry mechanism today through Docusign Connect, which automatically retries webhook delivery until your system acknowledges receipt. This Connect retry capability is separate from Maestro itself, but together they ensure both workflow execution and event notifications are handled reliably. To support resiliency at the workflow design level, you can incorporate escalation or fallback branches so that when retries are exhausted, the process is routed to either manual intervention or a defined error-handling path.
Good question! 💡
