Community ExpertAnswer
May 8, 2023 11:49 PM UTC
Thank you for the information, to confirm, you are not using the Document Markup feature?
If not, the behavior is expected, you can still add new text fields for other recipients in any part of the envelope, all the changes are recorded in the envelope history, and also at the backend, the fields are assigned to each recipient.
If the envelope is still open you can add new recipients to it, depending on the account configuration you might be able to add new documents to the envelope as well.
Christopher | DocuSign Community Moderator
Back to Docusign.com
