May 28, 2025 3:52 PM UTC
Webform Signature Connection Phone Number Required
I went to update my webform signature sections under recipient connections within the webform outline in my demo account. When I went into this page, it now states that each signing role requires a phone number to be collected on before I can save (under the signature section of the webform - see screenshot below). Before we only needed a name and email address linked from the webform for signers, but now it is requiring a phone number to be linked as well. Could this be because of we require ID.me for signers? Why is this required?
May 30, 2025 4:07 PM UTC
Hi ​@ally21cats  — thanks for the heads up on this.
I’m sorry for the inconvenience this unexpected behavior in webforms caused you. No worries; we will try our best to help you.
We’ve confirmed the issue, and our engineering team is actively investigating under ticket ID WEBFRM-7139. We know how disruptive this can be and appreciate your patience.
If you'd like to stay in the loop, we suggest opening a support case and referencing the ticket number, so you get notified of updates:
👉 Open a Support Case
Here if you need us!
If this helped, don’t forget to click “Best Answer”!
Jun 6, 2025 8:46 PM UTC
Hello ​@ally21cats,
Jul 8, 2025 1:47 PM UTC
We are still experiencing the same issue.
Jul 8, 2025 5:27 PM UTC
Hi ​@ally21cats
I’m sorry that the issue is still unresolved. As the engineers are still working on it, we cannot provide you with a specific timeframe for fixing it.
Have you already created a support case? If so, please have the ticket number via private message.
Jul 22, 2025 10:26 PM UTC
Hello ​@ally21cats
