Dec 17, 2024 9:48 PM UTC
To specify post-signing destinations for subsequent signers, or for the first, embedded signer of a direct PowerForm
I’m trying to establish a destination to a completed signed using power Form. The instructions provided to do so are these:
  1. In Docusign Admin, click Brands. (Learn more about these steps in the guide about Branding.)
  2. Locate the signing brand you want to configure and click the action menu and select Edit.
  3. In the Advanced Configuration section, click Destination URLs.
  4. In the Configure Destinations dialog, for each action you want to configure:
    • Click in the value box.
    • Enter the complete URL of the web page you want to direct signers to for the specified action. Example: https://www.google.com
    • (Optional) To add merge fields to the URL string enter a question mark (?) at the end of the web page URL, then add a query string with the name/value pairs of the contextual parameters you want to pass to the landing page. Click the INSERT MERGE FIELD drop down to select the field to insert. Example: https://www.google.com?name=[[RecipentName]]&email=[[RecipientEmail]] Note: Only Envelope Custom Fields will be listed in the INSERT MERGE FIELD drop down menu. Document Custom Fields will not be shown.
  5. (Optional) To reset any destination to the Docusign default, simply delete your custom entry in the field.
  6. To finish and save your changes, click SAVE.
Will this be specific and unique to the Power Form in use or will it use it for everything that is associated with the brand?
Michael.Rave
Dec 18, 2024 8:09 AM UTC
​@Yisa
The destination URLs will be for every envelope that is send with the brand you created, regardless if this is a PowerForm or via the Docusign Web App.
Michael.Rave
​@Yisa
Dec 26, 2024 4:37 PM UTC
Hi ​@Yisa,
