Jun 3, 2024 4:03 PM UTC
title and signature running into each other
When documents are being signed, for some reason the title and signature are running into each other and the name appears to be superimposed on itself but not in exactly the ame place, at least 2x. How does this get fixed? This is now the 3rd document from different people that this has occurred?
Jun 3, 2024 4:25 PM UTC
@Zed - Are you sending these envelopes from a template? To troubleshoot, if you are the sender, try creating a copy of one of the envelopes where this issue occurred to see if there are any duplicate standard fields.
ZedNew VoiceAuthor
Jun 3, 2024 4:26 PM UTC
Thank you will try this.
Jun 19, 2024 12:16 AM UTC
Hi @Zed,
ZedNew VoiceAuthor
Sep 9, 2024 10:03 PM UTC
Yes issue is solved. I didn’t create the envelope but received it therein was the issue. I asked for it to be deleted and resent by the sender and it worked fine. Thank you for your assistance.
