Nov 13, 2015 10:43 PM UTC
Tags are too small
When I try to use the function to have the client sign the document...it is TINY? What happened? I also want to add text...but the text box is also Tiny and I can't type any text into the box??
Nov 18, 2015 7:32 PM UTC
Welcome to the Community!
If you are placing tags on the document and they are appearing very small, this is normally caused by an uploaded PDF that was very large.
Each document has a page size and resolution(dpi) . DocuSign maintains  the resolution and page size when uploaded into the application . If the resolution is high or the page is oversized, then fields appear very small when placed on your document.
Learn more in Issue #2 of the related post: (https://support.docusign.com/en/answers/00004168) Any Tips for Uploading Documents?
You can normally resolve by either  1. Manually Changing the size of the tag.
2. Reformatting the document
Happy DocuSigning,
Marc
Happy DocuSigning,
Marc
Aug 2, 2016 7:56 PM UTC
My font size is too small. Signatures are not readable.
My font size is too small. And signatures are coming in too small.  How can I increase the size.
Aug 2, 2016 8:41 PM UTC
size of document as it loads
My document is about a 1/4 of the size that it should be. the signature tags are also very small and not adjustable as they usually are.
Aug 2, 2016 8:42 PM UTC
the document is too small to read. The sign only works once. doc still small
the document is too small to read.  The magniification button (+) does not enlarge the document.
Please advise.
Thanks
Aug 2, 2016 8:44 PM UTC
Very Small signatures and Certification
Why  are the signatures I receive back so small they are almost illegible.  The line from DocuSign on the upper  left seems even less than a #1 font.  No one can read it.  Why
Aug 2, 2016 8:48 PM UTC
Check the scale set on the tag.  There is a slider to the right of the tag .
Also the formatting properties of the Initial tag will have a 'Scale'  0-100% for the tag.  100% will be full size.
Why has the size of the requested initials changed? I'm the sender,Now I can even read it.
The initials that I requesting can not even be seen, I'm the sender before I was able to make out the intials and signature. Now its so small I can not see it.
Aug 17, 2016 6:03 PM UTC
Welcome to the community everyone!
If  you have scaled the tag to the maximum size  and it is still barely visible, this may be related to the resolution and dimensions of the document you uploaded. I have merged your question with a previously answered discussion. Please view the Best Answer at the top for more background and how to fix.
Happy DocuSIgning, Marc
Sep 12, 2016 3:04 PM UTC
my text is too small to read
my text is too small to read how do I make it bigger? The corner I dragg out and the text stays small.
Sep 12, 2016 3:06 PM UTC
Welcome to the Community,
Happy DocuSigning, Marc
