Nov 10, 2025 10:34 PM UTC
Standard Fields column will not stay locked in place
The standard fields column on the left and the formatting column on the right will not stay locked in place when I scroll through the document.
Nov 10, 2025 11:03 PM UTC
Hi ​@xxY12ss — thanks for the heads up on this.
We’ve confirmed the issue and our engineering team is actively investigating under ticket ID [NDSESEND-13037]. We know how disruptive this can be and really appreciate your patience.
If you'd like to stay in the loop, we suggest opening a support case and referencing the ticket number so you get notified of updates:
👉 Open a Support Case
Here if you need us!
Nov 18, 2025 1:34 AM UTC
Hi ​@xxY12ss.
How are you? Our engineering team confirmed that the ticket has been resolved. Could you please check on your end and let us know? If everything is working fine now, we would greatly appreciate it if you could mark this response as 'Best Answer' ✅ to indicate this topic as resolved. Thank you, and have a great day! 😊
👍and click "Best Answer"
