Dec 16, 2022 12:50 PM UTC
Simplified Chinese Character Display Issue
Hi There,
I uploaded a file with Chinese language, but these Chinese character unable to display properly as attached (only happened on DocuSign site). No any issue before upload and after download as the 2nd screenshot 'Normal Sample'.
I suspect there were some missing Font caused this issue. ​
Dec 16, 2022 2:33 PM UTC
Please try to flatten the document, you can find the steps in the following article: https://support.docusign.com/s/articles/How-to-resolve-a-document-upload-error-by-printing-the-document-to-a-new-PDF?language=en_US
Dec 17, 2022 1:11 AM UTC
@Nathaly Monge​
Hello Nathaly,
Thanks for your advice, I tried that and worked.
Regarding this file or case, just wondering what's difference between before and after the flatten? I found the font was still the same.
The file was automatically generated from SAP, should be only one layer I think.
Please kindly advise.
Thanks
Jan 2, 2023 1:33 PM UTC
Thank you for reaching back.
I'm glad to hear that it worked. There were possibly dynamics that are not supported by DocuSign embedded in the documents and by flattening it out, it just removes those dynamics, however, I couldn't tell exactly which ones would be messing with the font of your documents.
Jan 2, 2023 1:36 PM UTC
Hi Nathaly, Noted, thanks. All good now. Regards Jack
