Jul 16, 2024 3:10 AM UTC
Signer doesn't recieve envelope when more than one signer is assigned (with a set order)
Whenever I set a document to have two signers, the firs one (in our organization) never gets the envelope to add the first signature. I am forced to send the envelope multiple times. What am I doing wrong? This happens regardless of whether I check the “Set signing order” or not.
Any guidance is appreciated.
Dan
Jul 16, 2024 10:28 PM UTC
@Dan_Ornelas
Verify that email notifications are not being blocked or filtered into spam/junk folders. Sometimes organizational email filters can block these notifications or the user might have disabled them.
If they have a DocuSign account, is the envelope going to their Inbox in DocuSign?
@Dan_Ornelas
Jul 31, 2024 12:31 AM UTC
Hi @Dan_Ornelas,
