Apr 2, 2024 3:25 PM UTC
Setting up documents and tags
I am new to docusign - how do i set up templates, does my original document need to have blanks where the tags will be added.
Why am I unable to add custom tags?
Alexandre.Augusto
Apr 2, 2024 5:01 PM UTC
Hello, @MC24
Watch this video about How to Create a Template.
I hope that helps!
Alexandre
Alexandre.Augusto
Hello, @MC24
I hope that helps!
Alexandre
Apr 16, 2024 9:26 PM UTC
Hi @MC24,
