Jul 25, 2024 1:43 AM UTC
sequential transmission problems
Hello, I ordered it sequentially in the locusign and sent it, but it keeps changing to the simultaneous signature. How do I solve this problem?
Pawan Gangwani
Hero
Jul 26, 2024 6:45 AM UTC
Hey @Youngeun Kim
You will need to be an account Admin to locate the account-wide setting that sets the Signing order by default, please follow: Settings tab>>Sending Settings>>Enable signing order by default.
LMK if you need further assistance.
Thanks!
Pawan Gangwani
Hero
Hero
Jul 25, 2024 7:38 AM UTC
hello @Youngeun Kim
I hope you are doing great. You are setting order while creating the envelop right. refer the ss below:
Jul 26, 2024 1:19 AM UTC
Pawan Gangwani wrote:
hello @Youngeun Kim
The check is disabled. What's wrong with this?
Pawan Gangwani
Hero
Hero
Hey @Youngeun Kim
Thanks!
Jul 29, 2024 2:09 AM UTC
@Pawan Gangwani Is this what you're talking about? I can't set the order even if I set it with that..
Pawan Gangwani
Hero
Hero
Jul 29, 2024 6:19 AM UTC
Nope, in the eSignature account setting, you will see the signing setting in left side panel where you will get the option to enable the signing order if not then you have reach out to DocuSign support and raise a ticket.
Thanks!
Aug 12, 2024 8:01 PM UTC
Hello @Youngeun Kim ,
